  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
nah not yet.
I want to find a RB25DET recoed, but I think I will have to do the wrecker thing :D
RMA has a halfcut at the moment but they want to sell the whole thing and I only want the engine, don't need the rest.
what I will do is drop a new engine in, rebuild the old one with a RB30 bottom end and forgies and all that crap put that back in and then resell the other one.
Won't be too much out of pocket that way (over time that is)
We got stuck at that round about for so long.
So what happens now adrian? So much for getting the bike cause they get less cop attention.
Later on.. i saw a bike flying up the right hand lane, I was there trying to catch up to cars in front (frizzle and stuff) and Ian goes "your friend on the bike is coming up the right hand lane" .. I'm like "oh ok" so when he was flashing me I thought it was you.. then the blue and red lights come on i'm like WTF?! .. then i went off at Ian saying "you could have specificed if it was adrian or the cop" cause i just thought it was adrian flashing me to say he was there.
no, I saw the light.. victoria was turning into a dull police state!
queensland suits me to a tea.. I like sitting around drinking beer in the sun or down near the beach.. and I don't get worked up over pointless things.. that *is* being a queenslander!
hell i'm working from home earning good money.. the beach is 10 mins away with loads of hot chicks.. I have the house pretty much setup now with all the usual goodies.. i got a new toy in the garage, and I'm feeling nicely relaxed.. why would i go back to victoria? unless forced :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
