Ok your into interesting fact hey....
Well....
I got one....
Ummmmmmmmm.
75% of statistics are made up on the spot.....
hahaha :P
statistics can be used to prove anything..... 82% of people know that
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Babies are born without kneecaps. They don't appear until the child reaches 2-6 years of age
So all those babies I have been kneecapping lately has all been for no effect?!!!
damn it!! i knew they weren't screaming hard enough..
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
