  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
- Lincoln and Kennedy were both killed on a Friday.- Both were killed in the presence of their wives.- Both were shot from behind and in the head.- Both assassins were killed before being brought to trial.
Like all insects, ants have six legs. Each leg has three joints. The legs of the ant are very strong so they can run very quickly. If a man could run as fast for his size as an ant can, he could run as fast as a racehorse. Ants can lift 20 times their own body weight. An ant brain has about 250 000 brain cells. A human brain has 10,000 million so a colony of 40,000 ants has collectively the same size brain as a human.
The average life expectancy of an ant is 45-60 days. Ants use their antenae not only for touch, but also for their sense of smell. The head of the ant has a pair of large, strong jaws. The jaws open and shut sideways like a pair of scissors. Adult ants cannot chew and swallow solid food. Instead they swallow the juice which they squeeze from pieces of food. They throw away the dry part that is left over. The ant has two eyes, each eye is made of many smaller eyes.
They are called compound eyes. The abdomen of the ant contains two stomachs. One stomach holds the food for itself and second stomach is for food to be shared with other ants. Like all insects, the outside of their body is covered with a hard armour this is called the exoskeleton. Ants have four distinct growing stages, the egg, larva, pupa and the adult. Biologists classify ants as a special group of wasps. (Hymenoptera Formicidae) There are over 10000 known species of ants. Each ant colony has at least one or more queens.
The job of the queen is to lay eggs which the worker ants look after. Worker ants are sterile, they look for food, look after the young, and defend the nest from unwanted visitors. Ants are clean and tidy insects. Some worker ants are given the job of taking the rubbish from the nest and putting it outside in a special rubbish dump! Each colony of ants has its own smell. In this way, intruders can be recognized immediately. Many ants such as the common Red species have a sting which they use to defend their nest.
The common Black Ants and Wood Ants have no sting, but they can squirt a spray of formic acid. Some birds put ants in their feathers because the ants squirt formic acid which gets rid of the parasites. The Slave-Maker Ant (Polyergus Rufescens) raids the nests of other ants and steals their pupae. When these new ants hatch,they work as slaves within the colony. The worker ants keep the eggs and larvae in different groups according to ages.
At night the worker ants move the eggs and larvae deep into the nest to protect them from the cold. During the daytime, the worker ants move the eggs and larvae of the colony to the top of the nest so that they can be warmer. If a worker ant has found a good source for food, it leaves a trail of scent so that the other ants in the colony can find the food. Army Ants are nomadic and they are always moving. They carry their larvae and their eggs with them in a long column.
The Army Ant (Ecitron Burchelli) of South America, can have as many as 700,000 members in its colony. The Leaf Cutter Ants are farmers. They cut out pieces of leaves which they take back to their nests. They chew them into a pulp and a special fungus grows it. Ants cannot digest leaves because they cannot digest cellulose. Many people think ants are a pest but I like them. To stop them coming into my kitchen I put some sugar outside. They they have so much to eat that they are not interested in coming into my kitchen.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
