  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
My family loves it when I'm around and theres prawns, cause I like peeling them, and they like eating them :P
So it's win win for everyone!
Rip their heads off and suck their guts out!
i hate this week!
i been at work for the past 9 days over the xmas break. 12hrs a day + more.
now taking 2 weeks off. going to be sitting by the beach and fixing up car. got pics from the storm up here now. from the weekend
dont think about work... its a bad thing to do on holidays.. think of what you can do during the day while you are enjoying your holiday. think about work the day you go back. works a treat for me.
Cheap... I like it :D
Pfft, holidays, what are they? I'm at work right now (ahem) setting up a sysprep Win2K image. Yay. And my sunroof leaks now too, due to damage caused by (I suspect) a vandal while it was parked... :)
Be careful theres no tsunamis!
yeah true... and the sharks... and the cancer causing sunburn.... and the drive to the beach and possible car park rage.
stuff this i am staying home and swim in the backyard pool :)
True true.
I'm going to get my hair done today :) And then.. not sure. Andrew wants to go for a drive tonight, but I'm sick of driving, the amount I did on fri/sat/sun last weekend was bullshit.
hair done? isnt that like 3-4hrs in the comfy chairs chatting and having coffe and getting pampered...
guys idea for a haircut is in and out in 15min... mmmm might be onto something there :think:
Pfft, holidays, what are they? I'm at work right now (ahem) setting up a sysprep Win2K image. Yay. And my sunroof leaks now too, due to damage caused by (I suspect) a vandal while it was parked... :D
oo unlucky... people have no respect nowdays for cars :)
Hahah.. Soo true. I have to get my re-growth done again. My sisteres a hairdresser so 2 hours worth of work to my hair costs me $5 .. but only when she asks for money cause her boss is there. I normally get about $100 worth of stuff done. It's awesome having a sister as a hairdresser. Cept when I was the guinea pig. Back in 1996.
Andrew will probably get his hair cut too. 10 minutes :)
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
