  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cool can I ask a question....what is the difference between a R32 and R33 and R34 and all their shapes and sizes and can you tell me if my 21"x12" chromies will fit on my N/A 32, front only? Can I take the brakes from my mums SLK and put them on my R34 GTR that daddy just bought me coz they are cool red ones and the GTR has gold ones(ghey) Also I tried dragging a McClaren in my friends R33 GTST with a RB30 bottom end and we were winning up to the first 50 metres then the McClaren just past it, but it was a very close call, is it true that if he put a green coloured pod filter on we could have won?
ahhh the mensa folk may lack social skills, but what they lack in social skills they more than make up for with their scorn for everything.
rofl.
wrong.  I'm at an intraweb cafe'.  I heard you were moving.  What's the go with that?
WTF, lmao. Im not moving unless I get a job, and you give me free rent.
I think you mean niz33.. his moving down for Uni.
Haha @ cafe`, your so picking up nerd chicks.
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
