  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cool can I ask a question....what is the difference between a R32 and R33 and R34 and all their shapes and sizes and can you tell me if my 21"x12" chromies will fit on my N/A 32, front only? Can I take the brakes from my mums SLK and put them on my R34 GTR that daddy just bought me coz they are cool red ones and the GTR has gold ones(ghey) Also I tried dragging a McClaren in my friends R33 GTST with a RB30 bottom end and we were winning up to the first 50 metres then the McClaren just past it, but it was a very close call, is it true that if he put a green coloured pod filter on we could have won?
ahhh the mensa folk may lack social skills, but what they lack in social skills they more than make up for with their scorn for everything.
rofl.
wrong.  I'm at an intraweb cafe'.  I heard you were moving.  What's the go with that?
WTF, lmao. Im not moving unless I get a job, and you give me free rent.
I think you mean niz33.. his moving down for Uni.
Haha @ cafe`, your so picking up nerd chicks.
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
