  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Sounds like Gary, his wife had twins about a month ago, taking his total up to three girls. He is seriously outnumbered now, even the dogs are female! He's a bit of a bitch too, so I suppose you could say that there are no men in the house :mad:
speaking of kids... was quite funny yesterday when i was making this video up for the boss that was leaving for PNG. one of the receptionists was sitting behind me when i had "broken" into the bosses personal files (as all good IT people can do). in there was a heap of photos of his little kids. she was like awww and ohhh how cute and such. i said are you getting clucky? she says yes so i say "GET THE HELL OUT OF MY OFFICE!!!" i dont think she appreciated that too much. ah well
people always seem to look instantaneously older and seem far more irresponsible once you find out they have kids. Except ska.
That is because usually people grow up mentally after they have kids, but no me, no sir-ee bob, still ages 5 mentally :mad: AND PROUD!
Which is why I get along with my kids so well, they are:
Girl - 6
Boy - 3
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
