  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Huh? You can joke all you want with me I dun give two hoots, why should it? :confused:
That was in no way directed at you, it was just a simple comment about the way Adrian responded to Paul's statement.
It was also a generalisation that normally men freak out when the word marriage is mentioned.
No I'm with Marc on this, unfortunatly I have already found that person, but at the moment she aint interesed........................................................... kinda, sorta, not really but yeah.
pfft sif!
~> -----Original Message-----
~> From: Adrian Strutton [mailto:Adrian_Strutton at blah.qld.gov.au]
~> Sent: Thursday, January 20, 2005 11:27 AM
~> To: cbharda at mydumbbox.com
Your message has been delayed and is still awaiting delivery
to the following recipient(s):
Message delayed
Your message is delayed
Message for domain mydumbbox.com delayed at blah.qld.gov.au.
Unable to deliver to domain for 8 hours.
Will continue trying for 64 hours.
No action is required on your part.
Last attempt failed because:
Can't connect to host
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
