  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
User Name Posts
chaos  6485
Ska  5423
BelGarion  3724
predator  3216
Nexus9  3080
strutto  3062
Genesis®  2674
Lazy-Bastard  2392
SmoothLine  2221
Charly  1838
NismoGirl  1827
Eug  1550
TeamKrazy  1493
jaqule  1423
NA_R33  1374
Nismo_Boy  1298
owned  1175
Oz  990
PlATiuM  989
FYN33  980
GTS-t VSPEC  806
rb25  735
EVO83  700
mindflux  650
wados  645
Nizmo  588
sileighty  558
Squizz  529
MJ  520
jlnewton  511
33NIZ  477
666DAN  440
rb26dett  351
V8skylineMAN  339
ok so i havent gone to bed yet...the weirdest thing is I have 510 posts in qld whoretown but only 477 total posts lol this always happens to me....
omg i cant belive how crap tonights late night tv is, its worse than last night, its all old ppl talking about how some special matress "Hugs and Moulds" to their body...my god their dodgy selling is so bad
just incase you were wondering it is also perfect for your futon bed...and you'll also get the specially designed pillow if you call in the next 17mins!!!!! WOW...and only 5 easy payments of 39.95 plus 19.95 postage and handling
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
