  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Werd...  My modem borked itself...  So now I'm back on dialup...  Oh the pain...
mmmm I can see adrian is going to be wearing his cranky pants soon
so the modem went :ufo: thats got to suck welcome to slow old school internet surfing
