Yeah, I am the ripper man,
A locomotion mind,
Love american style -yeah
I am the nexus one,
I want more life,
farker I ain’t done - yeah
More human than human
lyrics from "more human than human"
the best music to drive aggressively to
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
rob zombie has done heaps of stuff.. he even wrote a movie..
which i loved.. but everybody else seemed to dislike.. i don't think they "got" it..
then again it was kind of ****ed up..
House of a 100 corpses
it was cool :rofl:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
