  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Evah seen a 4 door auto N/A R32 do skids? It's funneh says:
I <3 cyrus.
Cyrus - Ska - Drift0r - Beggar Extraordinaire! says:
Wassup biatch?
Playing with my oversized penis.
Love your work, pics or ban.
Yeh, here you go.
Oh your so big and bad.
I try my hardest to impress my biggest fan.
A weekend in the life of V8skylineMAN:
Here is a list what i have done to that in the last three days
motor in....
crank is different...fark...need manual
get clutch fit clutch
get pedal box and clutch master and slave cyl from r31 and 200b and modify to suit application
manual in...
all anciliaries bolted to motor
gearbox is 5inches shorter than the auto
fark....manual out.....run around like an idiot looking for a long 5speed(impossible to get one atm)
find out that crank is NOT different...
there is an adapter on the end of it....pulls off with two tyre levers
put auto back in....
realize that i cut all the lines that the auto uses when i took it out as i wasnt using it
run around like an idiot again to find the cooler lines...
find some at murrarie.
remove clutch master slave and pedal and go get auto lines.
fit auto lines to gearbox....remember that the motor doesnt have an oil pickup in it yet...
undo engine mounts
lift engine and remove sump....
go 1/2 way to toowoomba to get oil pickup
fit oil pickup
fit sump...lower engine....do up engine mounts...
fill with oil...fill auto with tranny fluid
fit tailshaft
try to start car,,,....nothing
find that wiring is all wrong on the auto...
fix wiring...try to start car....
car starts.!!!....exaust isnt done up.....FARK its loud!
turn car off.
fit exhaust
start car.....runs on 5 cyls only.....
begin diagnosis
find that no2 cyl is not firing.....
plenty of spark.....
check exhaust....no popping....not a valve
must be fuel suply to Injector....nope...plenty of pressure..
guess that injector must be the problem...remove injector(cvnt of a job)
replace injector
start car...WOOOOOO firing on all six!
fit radiator and hoses
fit fan
fill with coolant
let the car idle for 20 mins
not getting hot, go for a small drive....temp on 1/3....sweet
sit down and relax
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
