  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
chris,
But I have heard at least three instances of where it has been mispronounced in the lyrics of music which kind of rules out the poorly educated bit. I hate the fact that I've learnt to live with poor spoken english to the point where I barley notice when people finish their sentences with preopsitions. (my most hated instance of poor english)
I was also reminded of how much slang I speak the other day when I was eating dinner with a couple who both spoke english as a second language.
chris,
I was the word fu(k and c^nt too much :P
Altough I do live in the sticks, and are muzza
chris,
I guess if you are hearing instance of mispronounciation in music, it would be from a songwriter trying to find an appropriate rhyme meter for a lyric. And so the corruption of the language continues unabated.
no.. americans are just ignorant ****ers.
I read some of his ruckus on the M5forums - One of the many forums spammed with this rally b/s. :)
I've been meaning to google search a bit more.
He's an ex hacker... Got busted hacking CIA, NASA, et al... Bargained with the US gov to "fix" their systems to avoid jail, and then went on to start an internet security company that he later sold for many millions of dollars...
The rest, as they say, is history...
He f**king rocks in the Gumballs... Always finished in the top 3...
