  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Scene: Brian and Dominic stand around looking at an engine in pieces. Things look grim.
Vin: Looks like your ride is truly hosed O'Conner. Don't look like you're gonna get that bucket of bolts ready by tomorrow.
Walker: hey Dominic, pass me that giant packet of zip ties.. I think we have hope yet!Maybe I still will get to rebuild my 2 second car and screw that girl by the end of the movie
Dominic Looks confused...
I want to see zipTie's in F&F3..
i reckon get rid of the smoke and mirrors and get back to what its all about....fastening your intercooler to your car with zip ties....using a screw as boost controll and fixing bog to half your bar to make up for all the chunks taken out on shit roads. Now thats what we want to see.....
Bwahahah... That's gold... Forward it to Hollywood now!
I want to also see in F&F3.. when they go off on a big secret meeting in an industrial area and yell "we go live in 5", they all get lost and follow each other different ways.. Some end up at each other's houses, some end up heading towards another state, and total chaos ensues.
Your computer is telling you something !slide...
i were trying to battle with smooth but in the creation it got out of hand and increased the pic size by 7000%
i got dual amd 2600 mp's and it was still crying my gig of registered geil was all used up
i should turn it into a virus :wassup:
:cheers: "we go live in 5" wat a classic
That too, is gold...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
