  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
ooo..new look..so maybe some good will come out of this.
yeah, thats the thing motivating me to get mine fixed. If i can get the new sideskirts fitted it will make the car a fair bit different to look at, so while i already know what it looks like "non-multicoloured", have no idea how it will exactly look with the whole 400R kit. Will look a lot more consistent too.
Exactly, It will breathe much needed 'freshness' into the look of it...
I gave up getting a new TS front bar, only place that had one was Top Secret, funny that... $1200 just for the bar, then add shipping... no thanks, im only going to crack it anyway!
Im sitting here thinking about the possabilities of installing a boost guage my very self..
You see me and anythign technical dont mix, i seem to break everything i touch..
but thinking about it, i think it would be a piece of piss to install a boost guage..
simply locate a boost line, snip it in half. plact a T piece in there..
then you have instant boost reading?
then you just have to wire the rest up to something to get the lights working!
maybe i should take a shot at it!
Pity.. but guess u gotta go in with the attitude "its not a show car, i drive it nearly every day", you'll always get a few small stone chips and the like. i used to worry so much at every little scrape.. now i couldn't give a crappa..
p.s. nexus.. tried getting out the back carpark when i was leaving - no friggin chance! ended up reversing all the way back when i saw the angle.. front way i managed to get out though without a scrape so all good :D
p.s. nexus.. tried getting out the back carpark when i was leaving - no friggin chance! ended up reversing all the way back when i saw the angle.. front way i managed to get out though without a scrape so all good :)
Blame it on the Lawyers next door they think it is angle parking, or at least park like it is.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
