  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
lol, could anyone else have had a door ripped off pred style? ok maybe Lol
haha.. true.. only me ! one in a million thing.. even at the time i was thinking "this can't be true.. am i dreaming?!" My door was one second ago perfect.. now its at right angles.
and my window, and that tint that I was really annoyed about that scratch only a few minutes before was lying 20metres down the road in a sticky blob on the ground.
nizmo - i think ill just get my mate to make one up off photos..
what more can i do.. its IMPOSSIBLE to be unique thease days :)
Ca18det conversion, with 2lt stroker and twin td06's.. thats different and hasnt been done :) kinda not really a skyline if it had a silvia motor in it then i spose.
Although there is a R33 with "light tune" Sr20det up for auction atm, which has catched my eye...
haha i just read this joke
First-year students at Med School were receiving their first anatomy class with a real dead human body. They all gathered around the surgery table with the body covered with a white sheet. The professor began the lecture by telling them: "In medicine, it is necessary to possess two important qualities as a doctor "The first is that you not be disgusted by anything involving the human body".
To illustrate, he pulled back the sheet, stuck his finger in the anus of the corpse, withdrew it, and stuck it in his mouth. "Go ahead and do the same thing," he told his students. The students freaked out, hesitated for several minutes, but eventually took turns sticking a finger in the butt of the dead body and sucking on it.
When everyone finished, the professor looked at them and said, "The second most important quality is observation." "I stuck in my middle finger and sucked on my index finger. Now learn to pay attention!"
this will make u think
Once upon a time in China, lived two Chinamen. One named I cum and one named No cum. No cum marry pretty Chinese girl named No cum tu. For velly obvious reason No cum and No cum tu not have any children. One day, No cum went out of town on business and I cum came over and spent the night with No cum tu. That night I cum came and No cum tu came too. This make both very happy. However about 7 or 8 months later, No cum see he about to become father but he not know how come, so when baby come, he named it, How cum u cum. Of course, I cum and No cum tu know How cum u cum came but to this day No cum not know how come How cum u cum came!
Cum again?
hey umart boys,
i have been purchasing ALL my PC gear from umart in brissy for years (ever since Computer Alliance fully ripped me off, called me a liar and left me pc less for 6 weeks)
im about to buy some gear for a mate who lives down the coast, but i was gonna put the order through up here
any chance u boys could give a fellow liner owner some sort of a discount if i put it through the coasty store?!??!?!?!
that would be tops
i buy computer gear all the time :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
