  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
is it work at home or office? i was at the milton Umart this arvo picking up the LCD and it was PACKED.
i reckon that it being on the table top the best. you can move it anyway you want and it takes up so little space.
i wanna get the 19inch next :)
nope.. flatmate owns the house and gets to park (wait for it.. ) his 80's camry in the garage.. therefore mine stays in the street.
Not too happy about it, but not much I can do .. 'xcept move :) thats the next possibility - I need a garage for other crap anyhow.. so soonish
yeah.. i been into milton to pickup my speakers.. was way busy. Goldcoast is a lot less chaotic.
I've only got a CRT atm, but my old work I used one occasionally and loved it. 19" LCD at the moment are bit pricey, but in 12 months they'll be pretty much at the level that 17" are now.
err.. milton.. its on the website: 28 Douglas St, Milton. Near the brewery.. actually what am I talking about its like right around the corner from your work :)
I think its the first right turn after maccas then you gotta turn into douglas st. . Only been there once so i forget.
im off to umart this morning to pick up my goodies
building a system for a mate
off to the computer markets tomorrow to get teh stuff i dont need to get new (monitor/keyboard/mouse)
i love umart, awesome prices, good gear, never had a scrap of drama with the brissyh mob!
What a load of shit my weekend is..
I had been hanging out for the weekend like no tomorrow .. and iw as excited because i was planning to take the 32 our, and hopefully meet some people .. as this guy i know was having a partyy..
getting all excited the weekend come, i read my star sign (yeah my ex got my hooked on that stuff, tryin to kick it) and all week it was sayign stuff like your going to meet a lovely ladie, roses are blooming yadd yadda yadda...
well considering my VERY messy break up and how shit things have been ever since ive moved up here .. i was excited that i was finally going to get a break.
i started putting the backseat in my car and hear my stomich winge to me .. so i solider on
and my head startes to playing some very loud bass.. not been able to take much more i went in to lay down on my back which feels like its been run over 50 times..
i slept for about 15 hours on and off .. and here i find myself, having to stay home as im sick as dog..
how typical ...
i swear someone has a hex or a voodoo doll out on me :)
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
