  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Woo HOO I got my stickers today, and I think he packed in an extra so I got all 3 now :) might go home and wash those parts off and stick them on, as then it'll be sitting at Gav's for a while, might do a bit of advertising for the site :D although I think a lot of the people who go there are from here :D
smooth: too late. Just got back.. I was down there earlier. **** that area is a BROTHEL. I was paranoid about my car getting wiped out by trucks, crazy tradeys and god knows who else. Worst possible street for it, so narrow, no room for parking, etc and you can barely get into the actual workshop car area itself to park. Be very careful if you go down its seriously dangerous.
..but in good news..
NEW SIDESKIRTS!!
Ended up getting blitz ones as they fill the line a lot better and come down low like the front bar. Should look pretty tough onces its all fitted. Ended up being $350 which was a bit more than what I wanted to pay (was expecting $300), but as long as they come up nicely doesn't really matter.
Here is my amazing "artists" rendition.. Bit hard to picture them on though.
not too traffic island friendly though! going to have to watch that :D
thanx :D Photoshopping is kinda my gig.. but not getting me work in that area at the moment.
I am sure they will look much better once painted... i just kind of stuck them there (notice the sticks :)) I'm amped to go and find some panel shops now, just get it all finished and back to "normal". Will do that next few days. Its been some 3 months I've had to drive it along all stuffed up like that.
Going to chase some panel shops up this week. Hopefully book it in next week if I can. So not too long.
Wing stays. In fact once I get it all fixed up, may well be putting it up forsale -- so no point stuffing with it too much.
lol - yeah drifto style - if only the reality was so glamourous.. hence my sig :)
yeah, i know :) but just want something bit cheaper and faster -- and to make it faster would cost me another $5k, as its already maxed out really with the stock turb .. would like to buy a house soon and considering importing a couple of cars b4 the 15 year rule to turn a few quick bux -- if its at all going to be possible before they end it.
Would still be a nissan turbo - just more around $12k than $20k.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
