  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Well raced home and put the three wheel'd beast out for collection tommorrow morning, also stuck the stickers on, BEWARE MJ the small ones are not directional, although I did make mine that way after a bit of fiddling, I was going to bring the digicam home rom work, but left in a rush to get to the tyre shop to pick up my mag that I forgot it, and then when I got there they were closed anyway !!!! :cuss: Bah hope they are there right on time in the morning other wise I'm gonna be late for work , grumbles.....
yeh i had a bit of trouble putting the little ones on its hard to line it up against the red background bit, this set i got today is my second set. First set got water damaged and was farked so i hope these turn out good. Yeh i also noticed they both are identical and will be opposite ways on the side of the car but it doesnt bother me. Did u put urs in that little 1/4 panel glass? i reckon they look the best there. I also got the big one up the top of the rear window
i got mine just on the door below the mirror on the passenger side. It's cool, because you can actually see people when they are checking out the sticker :)
I've seen quite a few people check it out -- probably wondering what crazy street racing gang I am part of or something. Its funny, especially the old codgers.
Yupp same places, except I altered the small one on the passengers side, put the red rings on upside down, so that they face the front, and then put the bottom writeing on to fit and then moved the top writing in to close to the red rings, looks sweet as :)
I have my car back..... phew
It is running all nice now and I can stop soooo much quicker now (go the slotted rotors)
Plus had time to sit down with Gavin and start on a roadmap for 250KW at the rears :)
dyno day?!
im in .. i wanna see what figure my car currently makes as its the same since ive purchased it. so i can work out a goal figure that i want to reach
and pluss i wanna hopefully get a bigger figure then my bros r33 so i can rub it in :) (even though i know i wont)
but hey im dead stocker, but ill be in
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
