  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Well raced home and put the three wheel'd beast out for collection tommorrow morning, also stuck the stickers on, BEWARE MJ the small ones are not directional, although I did make mine that way after a bit of fiddling, I was going to bring the digicam home rom work, but left in a rush to get to the tyre shop to pick up my mag that I forgot it, and then when I got there they were closed anyway !!!! :cuss: Bah hope they are there right on time in the morning other wise I'm gonna be late for work , grumbles.....
yeh i had a bit of trouble putting the little ones on its hard to line it up against the red background bit, this set i got today is my second set. First set got water damaged and was farked so i hope these turn out good. Yeh i also noticed they both are identical and will be opposite ways on the side of the car but it doesnt bother me. Did u put urs in that little 1/4 panel glass? i reckon they look the best there. I also got the big one up the top of the rear window
i got mine just on the door below the mirror on the passenger side. It's cool, because you can actually see people when they are checking out the sticker :)
I've seen quite a few people check it out -- probably wondering what crazy street racing gang I am part of or something. Its funny, especially the old codgers.
Yupp same places, except I altered the small one on the passengers side, put the red rings on upside down, so that they face the front, and then put the bottom writeing on to fit and then moved the top writing in to close to the red rings, looks sweet as :)
I have my car back..... phew
It is running all nice now and I can stop soooo much quicker now (go the slotted rotors)
Plus had time to sit down with Gavin and start on a roadmap for 250KW at the rears :)
dyno day?!
im in .. i wanna see what figure my car currently makes as its the same since ive purchased it. so i can work out a goal figure that i want to reach
and pluss i wanna hopefully get a bigger figure then my bros r33 so i can rub it in :) (even though i know i wont)
but hey im dead stocker, but ill be in
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
