  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
well considering NEX is going to give me a job :):D:)
Seriously if you are interested send your resume to me at [email protected] I need you to have at least an A+ qualification and preferably at least an MSA too.
Nothing really going right now but you never know what will happen in the future.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
