  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Fronts only? Is that fitted? Keep your pads?
Sorry for the q's... It's coming up on my list of mods too...
Yeah fronts only, not fitted, doesn't include pads either.
Probably could have sourced them cheaper but I needed them done pretty quickly.
uhmm before i send all this stuff off to you, what exactly do you do with compyters:D
We sell computer hardware and assemble/fix computers, setup Networks etc etc
go here for link ... www.umart.com.au
yer mechanical are probably the best in my opinion, tho apparently you can be defected for a mechanical boost guage as you are bringing engine vacume through the firewall which is illegal???
can anyone shed some light on that?
I've heard something similar...
But, the old commos had an economy gauge in dash which read engine vacuum... And the old Mercs had vacuum assisted central locking... So there is a few arguing points...
for pads strutto, see the guy at brake distributors labrador, and get yourself a set of rb-74s
if your getting slotted rotors, these are the pads to get
i got em on my car atm, they only squeal a bit cause the faces get a bit glazed sometimes,
slip runs the same pads on his 31, and if uve ever seen that thing stop, ull definatly agree they are good pads
$520 isn't too bad for slotted..
If you can catch me unawares you can steal mine strutto :)
Belgarion: could be? But still, you'd have to be pretty unlucky to get defected for that. Haven't heard anybody in australia getting defected for that. But i'm sure a cop could try it. In VIC they tried "exhaust too big".. lol
nexus9 i know you assemble computers at umart, my friend buys em off ya,
i used to buy all my wintel pc parts at umart when i was into pc's but in those days, i had to drive to milton to get the parts too
mick51 from here used to work for umart too if i remember correctly, in the RA dept
Yah... rb74's are on the list... But gunna do rotors first... Should rotors be bedded in with new pads or old pads???
ann you work for umart, gotcha i know what they do..
Mate just a bit of advice for me here, if i was to head off to that field of work would i be able to get in without a MSA and the other thing. considering my other qualifications?
In all honesty cert 1,2 and 3 don't mean a hell of a lot until you take the step to sit for your A+. If you have those certificates then an A+ shouldn't be too hard.
You could still get in the industry by impressing me with your real life knowledge for example.
But I think a little more study may be in order.
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
