  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hehe.. good one, i'm never going to hear the end of it till i get it fixed am i ? :cheers:
no, he's talking about WORK .. woohoo! kinda sad, but hey, it will be good to be doing something productive again! :D sitting around all day is kinda getting a tad boring now
