  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I had my eye on a pair of Adidas Casuals, but ended up with Some Nike ones.
What i dont get is. they had the EXACT same nike shoe, one had a blue 'swoosh' the other had a silver 'swoosh' .. i liked the silve pair. but they were $150, where as the blue pair were $80 .. and they were the exact same make and model.
Doesnt make sense to me
WTF is a puma frankenclyde?
(edit) I don't think that I could ever wear those in public.  They are VERY white.
lol....not a huge fan of white myself, thats the first pic I found
They come in all sorts of colours tho
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
