We sell Plasma screens and projectors occasionally and of course TV tuner cards but the true HTPC stuff not yet.
To tell you the truth hadn't thought about it much. Must admit that you are the only one who has ever asked me about HTPC items.
I could probably get it, if you can tell me the manufacturer and model number of the item/s you are after
  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
pffftttt....leadtek....no thanks....I went top shelf and got a Hauppauge PVR-250....well almost top shelf, and a Sigma X-card
Does the job VERY nicely
The X-card outputs to the TV at near DVD quality, and I can do all my TV recording on HDD
..well its inevitable that a topic about "who is best out of betty and wilma" and cartoon characters is only going to go into bad territory.
What sort of a/v tech stuff? private home theatre, industry stuff or ? my old man is a bit of an a/v tech himself in melb actually.
sound video and lighting installation and operation on a short term basis mostly....the occassional permanent install
fairly basic.....
pvr has a hardware mpeg2 encoder and analogue tuner
xcard has hardware mpeg2 decoder, therefore taking all the load off the CPU for both encoding and decoding
120Gb 8Mbcache HDD for recording and storage
733 celeron and 512Mb RAM, more than adequate considering above
pioneer dvd rw for playing and burning
the xcard also has DTS5.1(think thats it) sound out
control is via an application called "joveplayer" and the xcards remote
thats about it really
and a NIC to network to my leech box so I can play all the movies I download straight to the TV
works quite nicely, and the picture quality is better than I was getting with the tuner in my TV, and equal to the output from my stand-alone dvd player
yup, you and the rest of australia :) (and me). The saddest thing i ever saw was about 2 years ago at Telstra, one of their wanky display "this is what we do" places, had about 5 state of the art 108cm plasma screens sitting there just displaying bullshit like "telstra - the way of the future" and basically a powerpoint presentation, over and over, and probably still to this day. I had tears in my eyes.
I wonder wheter plasma ever hit mainstream before big screen LCD ?
the only issue i have with lcd is the brightness, even though the lumens count keeps getting higher as new models come out, in full daylight there is still a washout issue
gimme a plasma anyday, even though you don't get the same screen size as a projector, the novelty of a big screen wears off after a while.
I used to bring home projectors from work all the time, but after a while you kind of get over the big screen thing
You do? :D prob is the depreciation on home theatre is almost worse than a car or a PC. Advantage is the PC is generally under $1500, where as home theatre isn't :)
i know police can defect you for gauges being above or on the dash or something similar to that never heard for being defected with gauges though.
but with the boost controller its different i know cause most people put it where police cant see unless the really look for it.
How in depth have you gone with your home theatre Warrick?
//start waffle
Hmmm....probably didn't answer the question there....went off on a bit of a tangent:D, and also I tend to misunderstand questions and give the answer as I understood the question to mean (if that makes sense :S)....lol
Not too in-depth is the answer I guess.
No surround sound...it's never been something that I was interested in from a home point of view. I used to run a pair of Inkel power amps (300w RMS per side or 600w bridged), one driving a pair of Peavey 12" and horn PA speakers and the other driving a 10" sub, but sold the Peaveys as they were more a pure grunt speaker rather than a "high fidelity" speaker. Now I just have a pair of Tannoy bookshelf speaker and the sub, but I rarely use the system for the "audio visual" experience, more just for music.
And on the visual side just a 29' TV.
One day when we do some renovations and have a dedicated "theatre" room, where I can do a permanent installation, I guess I'll get more serious about it.
//end waffle
during the week (apart from thursdays :)) I really only drive to and from work, which is like a 2 km journey each way, so the car doesn't even get at chance to warm up....kinda defeats the purpose. I probably should buy a pushy or catch the train.......
Nahhh I only live like 6kms from my work so my line doesnt have too much time to warm up either, bought a pushy, and have only used it to get to work when the car was off the road, I just couldnt be bothered riding, not when the line beckons :D
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
