  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
oh well john you're not the only one :) last skidpan day in melb i came out and lost my old front bar... haha. Can take a toll on the car..
mindflux -- there are like relays and things in a separate box (i think) which you could look at. I know in my 33 there are fuses in the back for LHS and RHS headlight, then there are a couple of doovas in the engine bay listed a "LHS healight" and "RHS headlight" in another fusebox for some reason Even the actual light stalk can have probs which causes the lights to act funny. Autoelec will charge you a couple of hundred at least to fix it.
fully its never ending, got home and felt like selling it, i think im gonna flog the kit off, and get a stock body kit again, when i get some spare cash, or consider a genuine plastic do luck kit from the states
Fark John... Keep your chin up! Your car looks awesome ATM... Pre Skidpan that is... Don't go back to stock!!!
Plastic kit sounds nice though...
yeah know the feeling.. kits can be bitches.. this is my 2nd front bar, and when i get the sideskirts fitted my second lot of them. While being low looks shithot and it handles better, sometimes you gotta wonder. Even with plastic you'll scratch the shit out of the paint and crap.
also mindflux.. just buy a multimeter ($20) and learn how to use it :) That will at least allow you to isolate the problem. You basically just stick the probes at different points and check you're getting voltage at each point. Soon as you find the point where there isn't any voltage anymore that is your prob.
well the box is generic and can vary depending on the options shipped with your car so you might not necessarily have all of them.
you *have* taken the bulb out and checked it haven't you? Bulbs are $7 from anywhere basically. Its always good when you check and it is the bulb, and you go "phew".
I had light probs in my old r31.. cost me $250 or something to get fixed, just for some simply shitty problem.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
