  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
oh well john you're not the only one :) last skidpan day in melb i came out and lost my old front bar... haha. Can take a toll on the car..
mindflux -- there are like relays and things in a separate box (i think) which you could look at. I know in my 33 there are fuses in the back for LHS and RHS headlight, then there are a couple of doovas in the engine bay listed a "LHS healight" and "RHS headlight" in another fusebox for some reason Even the actual light stalk can have probs which causes the lights to act funny. Autoelec will charge you a couple of hundred at least to fix it.
fully its never ending, got home and felt like selling it, i think im gonna flog the kit off, and get a stock body kit again, when i get some spare cash, or consider a genuine plastic do luck kit from the states
Fark John... Keep your chin up! Your car looks awesome ATM... Pre Skidpan that is... Don't go back to stock!!!
Plastic kit sounds nice though...
yeah know the feeling.. kits can be bitches.. this is my 2nd front bar, and when i get the sideskirts fitted my second lot of them. While being low looks shithot and it handles better, sometimes you gotta wonder. Even with plastic you'll scratch the shit out of the paint and crap.
also mindflux.. just buy a multimeter ($20) and learn how to use it :) That will at least allow you to isolate the problem. You basically just stick the probes at different points and check you're getting voltage at each point. Soon as you find the point where there isn't any voltage anymore that is your prob.
well the box is generic and can vary depending on the options shipped with your car so you might not necessarily have all of them.
you *have* taken the bulb out and checked it haven't you? Bulbs are $7 from anywhere basically. Its always good when you check and it is the bulb, and you go "phew".
I had light probs in my old r31.. cost me $250 or something to get fixed, just for some simply shitty problem.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
