  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
the other cooler i bought is for a mates GT starlet and im pretty sure he would interested aswell so count me in and it doesnt bother me if the workshop is in brisbane or the gold coast if we can get it cheap i will drive any where.
Also did the deposit go through thanks Wade.
jaqule - drop me a PM ... the intercoolers should be done in about 4 - 6 weeks im guessin
drop me a PM so i can work out a list
wade - drop me a pm .. same as above
im pretty sure it went through .. i past the informaiton on to AVI .. and we should know by friday deffinatly.
i got a soft sport for starlets :D
i posted up some Expression of interest threads.. and ill let them run for a bit, in the mean time i will collect a list of workshops to contact.. and as the time gets closer i will contact them and see what i can work out
Well bring em on MoFo
Most members I have seen on the Qld forum at once for quite awhile 13 members viewing....
Nexus9, 666DAN, cameron, daz73, EVO83, GenesisR32, kevwrx, Lach, MELV, Nismo32R, Ska, unwritten law, yamutha33
Oh and the amazing seethrough Mindflux made 14
All prolly patiently waiting round for strutto's PM :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
