  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Although they did have help from about a dozen commawhore drivers, still makes me laugh that wagon that was reving the shit out of it, still could not even break traction on smooth painted concrete! HAH AHHAhaHAHHAHhahahHA hHA!!
HAHAH MY NEW SIG OWNZ SKA!!
mwahhahaha .. time ot eat your soul
Could hardly read it, try changing the colour soit stands out a bit eh?!!?!?
Oh and try to find something in that black dark pit where my heart belongs, all that is left is nothingness and pure hatred!
Just saw footage on the news re GoldCoast Nightclub closing hours.... saw all the Nightclub owners coming out of council chambers..... never seen a dodgier sleezier bunch of people in my life and that includes the time I went to the Las Vegas Adult Video awards a couple of years ago
Hopefully its female hatred :D
Not just that, but there is a little there, lots of stuff boiling in the festering pit of rage, and think you walked along a very dark path in the middle of nowhere with me, STILL WANNA MMMAMAMahAuAUHAHUhAhAH hahHAUHHahHAh HAhAhAHaHAh!!!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
