  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
i guess not, the car has been so much more trouble then its worth honestly, the troubles i had with aresspeed, the number of incidents that led to it needing to go to the panel beaters, its been to the panel beaters 9 times since i bought it, only once was my fault. I had a gate fall on it, mum back into me, some ****wit back into me at KFC, got it resprayed gate fell on it a second time... no shit.... mum ****ed the front bar, it took me almost a year to get my kit out of ares and the kit is ****ed.
yeh tonight was good. Felt a little more comfortable than the last Jacobs well run. I dont know wether u all share my view that smaller groups are better than one HUGE one. I was reading a thread on another forum and how their cruise went to shit because of organisation and too many cars.
yeah i dunno, ill just get over the headaches with the new engine i suppose then have a long hard think about it, what u reckon a v8 skyline is worth?
Surely it's gotta be pretty priceless once it's up and running... Never seen or heard of another one....
Mid to High 20's?
frankly speaking... you have been in here long enough to know that you can NEVER get back money on mods or conversions that you done.
i am thinking of doing a conversion on mine to a RB25DET but at the end of the day when i DO decide to sell it... people is still gunna look at it as a 1992 model skyline.
