  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Id have to say im a bit pissed off whith ben posting page after page of '100 bottles on the wall'... I mean we all post random crap, but its in coversation...
Id hate to see this thread closed for good, its the backbone for all the shannigans on thursday night!
Yeah Matt,
That is the point, we all do it within a conversation, but having to sit and read through Ben carrying on singing about bottles or telling himself what is on tv page after page is getting a bit thin.
Admin/mods I think a friendly chat is in order....
I just skip it, problem is that that only works when you know that only Ben has flood posted, I mean I definatly do not have the time to waste and since I was the first home last night to post, I knew I prolly didnt miss a scarce post by someone else in that waste of space, hey strutto can delete them all on him :) wouldnt that be funny ;)
