  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
tsup wade . good call smooth it is a tuff one , yeah Ian did stuff up but I think they should have more then one heat or one event to see who does and does not go to the big rings
Agreed, I think they should have a race, Thorpe V Other guy, if other guy wins he deserves to be there, if not, well he doesnt :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
