  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
For that touch of 'queer' I think you need...
Hey josh, have any contacts that could give me a price on a rb26 for an engine swap...?
Have few numbers laying around some where. i'll find em, and pm ya. I cant get the rb26's for $3k any more though.. so the conversion cost's will be more now.
yeah, looked like u were having fun there jl.
I think i need to bring a 32GTR to the club :) don't think i have seen one on a cruise at all yet?
It was good to give it a bit of a hit out, I had full intentions of taking it easy, having not even had the car a week yet, but couldn't help myself.
awwwwww no more mates rates :)
Yeah drop me a PM, im off to finish work for the week and test drive my stupid car...
See what happenes :kick: I got a nice contact for a power fc pro at tuning, that is pretty good on price's, his re tuning the S13.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
