  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
I've had a slight electrical issue since it was N/A just looks like it's decided to become a major issue all of a sudden. I'm just glad that it happened before the turbo went on otherwise I'd be VERY pissed-off. It's a shame becuase the car has been no-dramas since I got it...then this has started up, got a good 75,000 of hassle free motoring though.
pity i'm not down the coast.. would drop in to watch it with you. i don't mind a bit of the sopranos myself, but never had much of a chance to watch much of the episodes. Its something i have to commit too but i'm not sure whether i am ready yet :)
