  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hmmmm the brake problem I would say is from the pad wearing down to the point where the squealers are just starting to hit the rotor, do you usually first notice it when you turn into a corner?
hello jl, hows things?
Would be great if I didn't have so many assignments stacked up and due this week. They have always done that around the mid-term break, never leaves much of a break, especially for those who still work full time. Probably doesn't help that there is a fairly large distraction around me at the moment.
I would not mind doing the tambo run I organised several weeks back again, got heaps of maps left over and it was a great run too, but I might have me kids that night, and if I do I might be out for the meet but not the cruise unless it is a tame one, not risking anything with them in da car :D
