  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Liek I said, there is plenty of places we can go, i havnt lived here long enough to know where stuff is..
but we cna go in to sufers and see all the thursday nigth cruises, (here was a heap last thursday)
we could goto hinze dam
we could goto tweed
we could goto mar-lool-umbar
we could goto byrone bay even :D
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
