  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Cut wire #53 on the ECU harnes to disable the 180 kph speed cut. The wire is yellow-green with a silver trace. Insulate the bare ends with tape. Maybe wire in a switch to enable / disable the speed cut.
Note:
This impacts the HICAS diagnostic mode - will not exit the diagnostic when 10kph is exceeded.
This mod is only for legal off street activities - ie drag racing, circuit racing, speed trials (eg the annual Ohakea trial) or if you live in a country where the speed limit is over 180 kph.
It is up to you to ensure your engine does not run lean at high speed - you will loose your engine if it does.
courtesy: http://www.overflow.250x.com/
Ok...what's with the birthday crap....you and I have the same b'day Erin....so following that logic.....It's your birthday too.....what's the go??....or am I missing some joke?
I dont know I just read a post saying it was your birfday and I didn't wanna miss out on the fun!!
But if it's my birthday too.. I'm kinda missing the FMIC i've been begging soo long to get :P
14.6.. but it had a blown motor... it was ticking madly when i got out for my time slip... should have done a mid 13.... thats wat i was hoping for....
id be happy with a high 12 now...   should do it... just depends on me really
And the gearbox :P
The car looks sweet though. I like simple; tint, lowered but not extreme and a good set of rims. Its a winning combination!
can you tell santa or the easter bunny or whoever is responsible for birthday pressies that I would like a FMIC too please, as well as a 3" dump pipe....thanks :)
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
