  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey all :wavey: good news i think! the credit card purchase of the parts went through yesterday so i can only assume thats when they were sent meaning ill see them tomorrow or thursday, meaning my car looses its 25de for eva tomorrow night :D
YES god YES!
hi cyrus, hope that you are feeling better now.
Yeah much better, still when you take one day of work off you always get two days worth of work piled up when you get back, hence my absence of whoring today :D BAH what a freking day!
Anyone know how long it takes to get your car booked into fulcrum if i was to go/call them tommorow?
Want to get whiteline handling kit put on and i get my car back tommorow :D
usually within a day. i was lucky once when i called in the morning and booked for a spot in the arvo.
Sup smoothman?
Im totally rooted and not in the exciting way... had 4 hours sleep and was up at 6 for a meeting at 8am which went to 1130am... then drove to brisbane with mum, came back and finished off some work and made some calls...
My head hurts :D
Feeling better mate?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
