  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
hey all :wavey: good news i think! the credit card purchase of the parts went through yesterday so i can only assume thats when they were sent meaning ill see them tomorrow or thursday, meaning my car looses its 25de for eva tomorrow night :D
YES god YES!
hi cyrus, hope that you are feeling better now.
Yeah much better, still when you take one day of work off you always get two days worth of work piled up when you get back, hence my absence of whoring today :D BAH what a freking day!
Anyone know how long it takes to get your car booked into fulcrum if i was to go/call them tommorow?
Want to get whiteline handling kit put on and i get my car back tommorow :D
usually within a day. i was lucky once when i called in the morning and booked for a spot in the arvo.
Sup smoothman?
Im totally rooted and not in the exciting way... had 4 hours sleep and was up at 6 for a meeting at 8am which went to 1130am... then drove to brisbane with mum, came back and finished off some work and made some calls...
My head hurts :D
Feeling better mate?
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
