  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
James u hit it on the head, accept the best one is, if you cannot change something, dont bother thinking or contemplating it, if someone wants to be a ****wit, then who are u to try tell them otherwise, let them be a ****wit and dont let it work yourself up about it. In short, i care about friends and generally am a kind person, but i tend not too care to much about stuff i cant change.
Another thig that helps me is that no matter how much someone pisses you off just remember, they have to get up every day of their life and have everyone know what a complete f*ckwit they really are. For the rest of their life. And you get to be you.
If that makes any sense to you at all.
glen ill sell u all that stuff, my engine is better though u shoudl just do the transplant ill sell it to u, safc engine everything the engine needs or that u want plus gearbox and clutch and other stuff u could possibly flog off 1000 bucks!
thanks for the offer... but its either me selling the car away or doing a turbo transplant later @ the end of this year...
usually within a day.  i was lucky once when i called in the morning and booked for a spot in the arvo.
Nice, thanks
What did you get?
How long did they take?
I basically want to get everything thats beneficial that i can, besides springs and shocks cos i already got them :D
got about $1200 to spend
did you goto the morooka fulcrum genesis?
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
