  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Hey i got a serious question ..
If you get pulled over and defected, they take a point or so off you..
However lets say im driving a mates car, and i get defected .. its not my car so can they take a point off me?
Certainly do. Doesn't matter if it's not your car, you were still driving a defective vehicle.
Just like if Andrew was driving the skyline and I was passanger, he'd get the fines for the defects and I'd get nothing. Because he was in control of the vehicle.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
