  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
john, didnt ur car have this crazy nismo sticker on it when u bought it?
Nismo sticker? where? my car looked the shizzel when i first bought it before i got it resprayed it had some very tasetfully placed stickers but no crazu nismo one it had a little nismo one just above the drivers headlight.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
