  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
thats y i drive like a nut! if i die having fun is it that bad? were all gonna die eventually why not doing something i love, touches wood i dont want to die soon but i certainly dont let it restrain me, pain on the other hand, that sucks
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
