  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
my grandfather makes turntables so we could have a few cars rotating, now i think that would be a first at autosalon and rub it in nates nose (owner of aresspeed) cause he always wanted one off my grandfather!
yes yes promo chicks, **** yeah now were getting somewhere ill start i suggestion thread tomorrow we need to plan, cause we could win the "look at that club" award that would be cool for our maiden year!@
