  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
kids are revolting seems 10 tonnes of chocolait and wall to wall dvd's of everything kidly you can think of isnt enough, might try to calm them down, they are fighting over a pillow, which means they're prolly tired :D
look @ it this way.. in 10 years' time.. they will be fighting over the keys to your GTR :D
No dey wont be, they'll be fighting over who pulls up next to me at the lights, as I'll have my R34 GTR and they'll prolly have R33 GTR's :D
CRAP BRB time to :slap: kids, bBAB aHha hahahahaH Aahaa no not really I dun think i could every whack my kids, just dun have it in me!
hey fellas.
whats the white paper thing on cyrus's siggie?
so many cops 2nite.. i got breathalised twice...
cop goes... had anything to drink? and I'm like uhh.. its still 6PM
and i had a coke... he goes blow into this till i say stop... and its
beeping, and beeping and beeping... half an hour later he says stop...
what a kunt
Hay ya Ben , yeah I had a awsome time , good to see a group of guys who respect there cars and know how to use them , not just a bunch of hoons who thrash the crap out of crap !!
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
