  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
no worries :thumbsup:
here is the post if you are interested
http://www.skylinesaustralia.com/forums/sh...3863#post773863
and a copy for those who can't be bothered clicking on the link ....
I will give them the benefit of the doubt, it is hard showing up to a group of people you don't know and being open.
People handle that kind of stuff differently, people say I am Aloof when I first meet them, all I am doing is trying to see if I can work them out first.
And having a car that has been targeted for Theft (i.e my old 215 RWKW S13 had been attempted to be stolen twice) I am very hesitant about answering questions about my car to people I don't know.
As I said I will give them the benefit of the doubt, if things don't change then I will bucket them with you :D
I completley agree with anna, i have already had a little chat with her about it, i dont think sau should be like this. I did say that mark should at least sign up and say gday, i understand that he is busy all the time but at least introduce himself.
The first couple of cruises i nobody came up and said hi or anything and i also felt asif there were seperate groups in the cruise.
I am a really quiet guy and i hope ppl dont ever take me the wrong way.
I dont think we should descriminate against anyone i am keen for anyone to come on cruises.
We all might have opinions about ppl but please keep you opinions to yourselves and not
bitch about ppl.
bitch about ppl.
:werd:
I think everyone that can make it should come to the dinner on this Thurs , that way it is a total social event , no cars , no groups and in an eviorment where we can all talk and get to know each other , without having to worry about where we are going who is meeting who .....etc .
Just remember take care of yourself and each other
my 2% of $1 AU
Thats it!!!!!!!!!!!!! Im done with my current job... it isnt heading where I want so everyone can just **** off!! Im sick of this shit...
/end rant takes deap breath...
Testify brother :angel:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
