  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
calamvale...yeah...rain sucks...my cars parked outside 2...was gonna wax tomorrow but not in this weather
Just checking, you are WAY too far away for me to even consider meeting at this time of night. Yeah I know about the car washing. I better do it tomorrow or glenn will yell at me. :) :kick:
have you tried cleaning your house?
:blah: whatever glenn. If you really want to see what sort of chaos my life is just think john's garage. But include my house, and everythig else about me. I think I'm undergoing a bout of apathy.
:wavey: hello knore, I've seen you on here before but never actually spoken to you. Looking foward to seeing the resprayed car tomorrow rain or no rain. :)
Just checking, you are WAY too far away for me to even consider meeting at this time of night.  Yeah I know about the car washing.  I better do it tomorrow or glenn will yell at me. :D :kick:
i will? :innocent:
i just freaking washed and waxed my car today... 2 coats!!!!...
maybe i will cycle behind the cruise tmr along the M1 :)
James.... what is ur preferance on??? exams or assignments??? i prefer exams to assignments
I'm pleased you asked nick, It all depends on what the split is between exams and assignments. It also depends how long the assignments are. If they're longer than 6000 words it really starts to get painful. Do you like exams or something nick?
Hey glenn,
Unfortunately fulcrum couldnt put me in till a week after the cruise :)
So ill be running wounded, but runnings thats for sure :D
Cars running good with new oil, would want to, its like the best oil you can buy.
No boost controller either, took shitty bleed valve off in preperation for the AVCR. So shes running a lowly 6-7pound at the moment.
Fronts missing the intercooler too, which will be on its way soon, cant wait !
Nice i love coldplay
Im usually a hiphop and tekno person (not ganster rap.. i like some good aussie stuff: Hilltop Hoods and most of the obesity records people, Clandestien, Muphin, Bias B, Resin dogs, The Herd...
My tekno is pretty selekt, not mainstream :)
But after all that, i got the both coldplay cds, and i love them both
So much emotion in music, its amazing
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
