  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
it didn't happen. after sitting in a panel shop for 2 weeks, you can only imagine the amount of dust in there. took one look at it n said 'f*ck this' and put the bonnet back down.
lol. you are gunna have to get around to it eventually. you should checkout out Predator's engine bay. its sweet!!.
Your just not cool enough for team owl :)
but yes the owl moment has passed, but i was given the owl as a presant for team owl so im making use of it
Too cool for owl? yes
Owl moment dead and gone? yes.
I think you bought the owl from cavil av.... common matty own up son! lol
