  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
seya !
Its always the assholes that get the hot girls, which is funny, cos most of the time the guy is good looking but the relationship hardly lasts cos she chose him purely on that.
Its the dont judge a book by its cover prophecy
yer might explain a few things about why i find it hard to attract girls
