  • Replies 62.7k
  • chaos
    7164
  • Ska
    5791
  • BelGarion
    3645
  • Nexus9
    3590
Older gals are better ive found,
more values instead of reactions. Altho some are too up themselves and try to own you. Its hard to find the right one, last gf was a year younger than me and used to get hell drunk and be ****ing stupid all the time. Pissed me off cos shed turn into like a 10 year old
mmmmmm :);) grrrr lack of self confidence sucks also
Dont forget you got the line under your belt man :(
Ive had countless chicks get wet over the skyline and want me to take them places :aroused:
I wanna start a skyline girls groupie posse and bring them out for cruises to do intimate photos with the cars :headspin:
Dont forget you got the line under your belt man ;)
lol dont get me wrong.... sounds pretty good.. but that aint me man.... tho i've not had a girl oogle at me cos i've got a line yet :confused: must be the driver :(
genesis-
Sam.... had a cry ... (eg: flux is a snob) ... because i .. (flux) ... ignored here existance
on saturday
oh... i... see.... but... i.. doubt.... she.. had... a...cry... becos... you... ignore... her..... i .. .reckon.. she... more .... relieved.... abt... it...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
